Hi everyone
I am trying to design a welded Iron tank whose caps are made of sections, then welded together. I made one section using Contour Roll on Sheet Metal, and worked fine, but when I made the Flat Pattern it mades a square. What I am doing wrong? Is it an issue? TIA for all the help, attached are images and the ipt itself
Best Regards
Solved by JDMather. Go to Solution.
@rreynoso1972 wrote:
..., but when I made the Flat Pattern it mades a square. What I am doing wrong?
You are not doing anything wrong - Inventor does not have the functionality to create the correct flat pattern for this shape.
