Inventor Forum
Isometrics Help!!!!!!!
3 REPLIES 3
327 Views, 3 Replies
In the Circle of the attachment is the part that I have trouble dimensioning when the right arrow is pointing i need to dimension that to the center of that hole which i cant seem to sanp to anything to get that dimension, in that general area of the left arrow. if there is any thing that anyone does knows please get back to me as soon as possible. Thanks!
3 REPLIES 3
rhasell
Hi
One thing you can try is to put a Work point on the solid model at the required snap point.
Then in the detail view, include the above created work point. (RMB on the point, select "Include")
See small example:
Reg
2024.2
Please Accept as a solution / Kudos
rhasell
The Other option is to create the dimension in question in the solid model, and then use the "Retrieve Dimensions" feature.
Reg
2024.2
ok so i tried the work point and it still would not let me get a dimension.
then i tried doing the retrieve dimension feature that worked it gave me the dimension but not on the right dimesion plane. i anyone knows anything please help.
thank you.
