I have a .Sat file I've brought into Inventor. The problem is that, as you can see from the attached zebra analysis, the faces are smooth and flush but I still have several unceccessary isolines. How can I get rid of them and I don't mean changing the view to have lines off I mean actually sealing the faces such that they erase the seam.
I can't really tell anything from the picture, but what does Delete Face with Heal do on this face?
or
Delete Face and then Patch (with appropriate edge conditions).
Delete face w/ heal seems to crash the program. Using the patch however tends to create hungry horse problems. It started as a polygon mesh, then I converted it to an Acad Mesh, then surface. Somewhere in creating a surface I get the faces but this looks bad when using IV.
@jpblower wrote:Delete face w/ heal seems to crash the program. ... It started as a polygon mesh,.
LOL what version 2012? 2013?
Polygone mesh... ..... I would just start over in Inventor using that mess, oops I meant mesh, only as reference.
There is a mesh smoothing and convert to solid tool in AutoCAD - but not sure how well it will work.
You are limited as to what you can do with surfaces. Another option would be to copy the objects, surfaces, to the construction folder and then rely on the surface editting tools within there to heal, stich, unstitch, etc. this is your best bet as Inventor is limited as to what can be done.
Don
@4donwan4 wrote:... as Inventor is limited as to what can be done.
Don
What are the limits?
