Inventor Forum
Is there a way Coiled Spring on an arc
2 REPLIES 2
Paul-Mason
618 Views, 2 Replies
Is there a way to create a Coiled spring of 26 coils on an arc radius of 3.781inchs arc length of spring is 13.706inc
The major dia of the spring is 3/8 inch with the wire dia is NOT given
The original Hand done drawing are attached in PDF version 6 format
As for Inventor I'm using 2012. It is the first time I have come across this sort of problem I thought of doing a single coil and creating a sub assemble of it around a construction line arc rad with each coil mated and rotated at an angle to the other but then thought that there must be  an easier way of creating this spring.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
2 REPLIES 2
harco
in reply to: Paul-Mason
Paul-Mason
in reply to: harco
Thanks I'll give it a try,
Inventor 2023 Pro
HP Z420 workstation
