Inventor Forum
Is it possible?
3 REPLIES 3
indalkar.dattatray
256 Views, 3 Replies
Is it possible?
Dear Sir,
Thanks you very much for your help. it is working.I have a  question ,
Is it possible to link one part file dimension to another part file?
1. Part first is a cylinder in parametric table i changed it,s name OD , ID  and thk. ( find attachment )
   Cylinder ID is ( ID=105)
2. Then i made 2 nd part whose step od ( od=102) is going to insert in to cylinder id.There is 3 mm clerance every time
3. so i have to make equction in 2 nd part that ( Step OD= ( ID-3).
means next time when i will change ID of cylinder OD of 2 nd part will ger changed automatically minus by 3 mm than id of cylinder.
Pls help.
With Warm Regards,
Datta Indalkar.
3 REPLIES 3
you might want to look at master sketch or skeletal modelling.  Alternativly, look at top down design
Stephen Gibson
View stephen gibson's profile on LinkedIn
You should use the function "Link" in the "parameters" and choose *.ipt. & .*iam file format. Then, When you modify the master part, you just have to open and update the slave part.
If you don't want to open your part to make the update you should use ilogic rules. try the plugin "Link parameters" who generate the ilogic code.
http://labs.autodesk.com/utilities/linkparameters/
Cheers,
John
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
Something like this?
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
