Inventor Forum
Is it possible to set the drawing Scale to the Title Block?
8 REPLIES 8
Message 1 of 9
Orest_iy
7131 Views, 8 Replies
Hello
Seems like it is missing parameter...
Orest
8 REPLIES 8
Message 2 of 9
in reply to: Orest_iy
Do you mean to do something along the lines of automatically set the scale value in the title block to the first base view? So that the value in the title block is dynamically updated with the base view?
Message 3 of 9
Orest_iy
No
Here is much more simple task.
I just want to see the actual drawing Scale in my Title Block but did not find this variable in any
of Drawing properties list.
Orest
Message 4 of 9
alessandro.gasso
Hi Orest,
If what you can read in our blog post below is not what you are asking for, please, provide more details.
Base view scale in title block
Thanks and regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
Message 5 of 9
Orest_iy
in reply to: alessandro.gasso
Alessandro
Thank you, it works!!!
Best regards,
Orest Yavtushenko
Message 6 of 9
Thank you for this.
Message 7 of 9
Talayoe
Sorry to revive an old completed thread, but it got my interest. I would like to know how one can accomplish this. I have my title block setup nicely. But on A size it goes off the paper a little, and on F size its so small you can barely read it.
How would one go about setting a scale factor based on sheet size to the title block?
tks!
-Randy
Inventor 2017 PDS
Message 8 of 9
SBix26
in reply to: Talayoe
We use two title blocks-- one for A & B size sheets, the other for C, D, & E.  They're pretty much identical, except that the smaller one is scaled to 3/4 the size of the larger.  Since they are almost never edited, that doesn't cause too much pain.
I suppose you could create a user parameter and have every dimension in your title block definition include that parameter as a multiplier, so you could set the scale for each drawing as you wish.  However, it would be difficult (impossible?) to change text size that way.  But, with iLogic there are nearly infinite possibilities, so you might look into that also (iLogic automatically chooses the correct border and title block for us when we tell it what size sheet we will be using).
Message 9 of 9
drguitarum2005
Reviving an older thread, is there a way to add this to just one title block and have it get the base view PER SHEET? Our drawings never have a "regular" number of sheets. One may have one sheet and another may have 30. I can't be making 30 different title blocks and whatnot. Thanks.
