Inventor Forum
Is Inventor Essencial for use AutoCAD 2013
2 REPLIES 2
xmiguelmonteiro
219 Views, 2 Replies
Hello, I downloaded AutoCAD 2013 students version and it came with Inventor Fusion, that i Don't need to use. However when I unchecked the inventor it appeared a message saying that AutoCAD might not work well without it. Is it like that or can I remove Inventor Fusion?
Thank you
2 REPLIES 2
Interesting.
I can understand if you were using Inventor and you removed Inventor Fusion thus getting that error, but AutoCad?
I personally never really use AutoCad myself (I have employees that are way more talented in it than I am) but I still never knew that AutoCad even used Fusion....not like Inventor uses it.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Hi xmiguelmonteiro,
Fusion can be used for 3D work in AutoCAD. If you're doing just 2D work you shouldn't miss it. Have a look at this link:
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013/Help/0169-Interope169/0172-Integrat172
I hope this helps.
Curtis
