Hi, it seems that there is bug with purge styles from assembly and child documents. I select checkbox "Purge Styles from all Child Documents" then push button "Yes to All" and "OK", dialog very quickly close, and styles are not purged.
Is this known issue? Can be this tested by somebody else? I use Inv 2014SP1 (build 222).
Petr
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
hi autodesk!
please, your comment about this problem.
@Anonymous wrote:
hi autodesk!
I just reported it again just incase..
Hi! This is indeed a known issue on R2014. It has been corrected on the internal build targeting as SP2 for R2014.
Thanks!
hi john, thanks for your respon,
we will wait new SP for R2014.
btw, is there any script ( in vba ) to handle this jobs?
because i have an assembly with hundred part need to be purges.
This still appears to be the case in IV2015 SP2 Update1 - the child styles wont purge. Can anyone verify the behaviour in IV2016 please?
I haven't noticed any problems with purging styles in 2016..
I think this may have re-appeared with either SP2 or Update1 for SP2. Is there anyone else using IV2015 that can't purge child styles when in a top level assembly?
