Inventor Forum
Inventor undo folder error
4 REPLIES 4
1758 Views, 4 Replies
every time I try to start inventor I am faced with a popup box that says
Error in Inventor Undo Folder: Please Make CorrectionUndo folder Error.PNG
And i can not enter any folder, nor can i click ok
please help
Tags (1)
4 REPLIES 4
johnsonshiue
Hi! I have never seen the dialogbox before. Could you try the followings and see if it makes a difference?
1) Before you start Inventor, right-click on the Inventor icon on desktop -> Run as Administrator.
2) Go to start menu -> Autodesk -> find the Inventor folder -> Tools -> Add-In Manager -> turn off all Add-Ins. Then restart.
Or, the disk space allocated to you is too small and Undo files cannot be written properly.
Thanks!
Software Test Engineer
in reply to: johnsonshiue
blair
It almost looks like you aren't using a Project File for Inventor.
Delta Tau Chi ΔΤΧ
in reply to: blair
Hey,
I had the same problem.  The reason was that there was not enough space on the hard disk.  I removed some other files en photo's and the problem was solved.
jef
