Inventor Forum
Inventor studio
9 REPLIES 9
Message 1 of 10
lis_wang
526 Views, 9 Replies
Inventor studio
I create a engine assembly and used "Drive Constrain" to rotate the crank shaft. The animation shows the crank shaft turns continuously in one direction. However, when I animate the constrain in Inventor Studio, the crank shaft turned in two different directions (see the vide file attached).
May I know why the crank shaft turns different direction?
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: lis_wang
Which of the 3 Angle Constraint types did you use?
Can you use Dynamic Simulation and Publish to Studio instead?
Message 3 of 10
lis_wang
in reply to: JDMather
Not matter I used Directed Angle or Undirected Angle, it is still the same. I created a animation by using "Drive Constrain"  and the crank shaft shows only one direction. Please see the file attahced.
Message 4 of 10
lis_wang
Any reply?
Message 5 of 10
JDMather
Attach your assembly here.
Message 6 of 10
lis_wang
As the file is too big, so I zipped into 3 files. This is the 1st zip file.
Message 7 of 10
lis_wang
This is the 2nd one
Message 8 of 10
lis_wang
This is the last one. Please unzip the 3 zipped files into one folder.
Message 9 of 10
JDMather
Make sure the planes used for the angle constraint share the same axis.
I used the assembly origin YZ and the DLM-006 YZ planes for the angle constraint and it worked fine in Studio.
Message 10 of 10
lis_wang
Thanks. It solves my preoblem.
