Inventor Forum
Inventor shutting down when you start a new drawing....
5 REPLIES 5
kevin2117
177 Views, 5 Replies
I am running Inventor 6, and I am having problems. Suddenly now, everytime I open Inventor and try to start a new .ipt file, it just shuts down the entire program. If there is anyone out there that can tell me what I have to do to make this not happen, it would be appreciated! Thanks!
Kevin J. Kaluf
Kankakee Valley High School
5 REPLIES 5
in reply to: kevin2117
What has changed about the machine? new software, patches, updates,
drivers, etc. ? What are the system specs?
> Kevin J. Kaluf
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4403 w/registry update
Dell UltraSharp 19" LCD
kevin2117
I did a Windows update on the laptop...... The specs on the computer are fine, because it worked before I did the update. I did a system restore to before i did the update, and i have taken Inventor off, then got rid of all mentions of it in my registry, and then reloaded it, and it still does the same thing..... I am very confused and frustrated! 🙂
Was the system restore from a point before or after IV was working? Are
you removing just the Inventor registry entries or the Autodesk registry
entries?
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
kevin2117
The system restore would only let me go to a point of the first Windows Update that I did on Sept. 1 (wouldn't let me go into August to get what it was befre then). Inventor worked up until I did that update, then i didn't use it until the last couple days. I removed all mentions of Inventor, Autodesk, Autocad, and Volo from the registry in regedit. Thanks for your assistance.... my email is kkaluf@kv.k12.in.us if you can help that way....
I don't work with laptops, so I am not sure what impact the system
restore would have on IV operation. At this point I would probably do a
reformat and install everything fresh. Hopefully someone that uses a
laptop regularly has some other ideas.
> Thanks
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
