Inventor Forum
Inventor section cut issues
6 REPLIES 6
craigcwc86
2352 Views, 6 Replies
I am trying to cut sections using Inventor  I will begin by saying I am a fairly new user. On numerous occasions I am running into an issue where the section cuts are not shown correctly, is there any advice on what the issue could be? I have attached an image showing an example of what I am talking about, you can clearly see that there are bolts and plates that should be displayed in the section cut which is shown above. Thanks in advance for your help!
6 REPLIES 6
Cadmanto
in reply to: craigcwc86
Welcomer to the forum.
Once you have created your section view, RC on the view and select "Edit View"
Then under the "Display" select as shown below.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
craigcwc86
in reply to: Cadmanto
Worked perfect thanks!
BLHDrafting
If you want what Scott has indicated to be permanent so as to always section Standard Content (that is items from the Content Centre) then turn this option on in the Application Options/Drawing tab.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
kkornocksr
in reply to: BLHDrafting
That worked perfect for my drawing, which is what I am most concerned with. Thank you.
However, if you open the assembly itself, and section through the middle, the o-ring still appears whole, which is very curious. It's something we live with, but it just seems wrong.
BLHDrafting
in reply to: kkornocksr
My assy sections fine. It will be the Section All Parts in Application Options. See the bottom picture.
Brendan Henderson
kkornocksr
That's perfect. All of my sectioning problems are solved. Thanks to all involved.
