I am having a problem with something I think should be easy. In the attached file, I want Pattern 4 (and some subsequent patterns) to follow the edge of the arch. Simple, right? But for some reason I cannot select the whole edge of the arch as a single edge in the pattern dialogue. Does this have something to do with my initial sketch of the arch for Extrusion 1 (Sketch 1)? Can I create a sketch based on Extrusion 1 that will have a continuous edge for pattern to follow?
Thanks for any advice.
-Andrew
Ahhhh,
I worked out solution in 2014 only to discover that you are using 2013...
I will try to remember to post 2013 solution on Monday (if someone else doesn't jump in here).
You are going to have trouble with the way you created the Loft. How will that be machined (can you show me the tool)?
When I do show you the solution - I am going to recommend that you push out the parts because the number of patterned features is going to get large (since this thing is symmetrical I think I will cut it in half and mirorr the resulting body(ies).
The CADWhisperer YouTube Channel
