Version: Autodesk Inventor 2013 , Vault Pro 2013
I am trying to open/checkout files from windows explorer and vault but they are being opened in a new inventor window instead of the same client that I had running beforehand. This problem just started today and I have not made any updates or changes.
Solved by jdkriek. Go to Solution.
In order to solve the problem you simply need to log-in as Local Administrator of the machine and start Inventor. Or a lot of the times right-click the icon and say "Run As Administrator".
Here's the background:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19171496&linkID=9242018
