I am use to Inventor locking up on my old machine with only 8gb ram, Now my computer is plenty fast but stll locks up.
Any ideas?
64gb ram
quadro k2000d
i7 3820 CPU
samsung 840 pro ssd
More information would be helpful. How often does it lock up? What are you doing when it locks up? What kind of work are you doing? How large of an assembly? (here's a good one) Bolted Connections? (they ALWAYS slow me down big time!)
Just generally more information about the conditions you see when this happens to you.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
See if anything from this thread pertains to you and if it helps you. Seems to me like it is a very similar circumstance.
Also looks like you are working on a large assembly. Maybe your modeling technique might be causing this as well.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
My assemblys are never any more than 100 parts, never use bolted connections, today it locked up when i clicked 'new part' nothing else was open.
It also locked up when constraining a flange to a pipe, when changing a frame gen part orrientation (rotated 90deg)
It seems just as random as inventor crashing all together.
What is your OS? Are you working locally or from a network? Vault? What version of Inventor is it?
Chris Benner
I am using Windows 7 PRO 64bit, all up to date.
Inventor 2013 with latest SP2 (update 1)
We use the vault to check out and then work from the checked out files on a local disk, my VAULT EXPLORER is on a 1tb 250mbs write 300mbs read hdd.
My OS is on a samsung 840 pro SSD 120GB
My projects are typically set up as follows:
Location = E:\VAULT EXPLORER\Projects\xxxx (Local disk)
Material libraries= J:\Inventor\design data\material library (Network drive)
Libraries = C:\VAULT EXPLORER\Libraries (SSD Local disk)
Folder Options:
Design Data = J:\Inventor\design data (Network Drive)
Templates= J:\Inventor\Templates (Network Drive)
Content center files = C:\VAULT EXPLORER\Content center files (SSD Local Disk)
Vault Options: =$/Projects/CLIENT
Publish folder: =
We are using Trend Micro security and i have tried disabaling it but doesnt seem to make a diference, i have also set folder exceptions for real time scanning to exclude all inventor working folders.
Hope that makes sense, Cheers
Have you logged a tech support case? Do you get the "crash report" screen at all? I think tech support may be your next move.
http://subscription.autodesk.com/sp/servlet/ts/index?siteID=11564774&id=13493891
Chris Benner
Every now and then we all get crash reports, some of us a dozen times a day, some will be lucky and get one or none.
I will pursue tech support, Thanks
I'm getting nowhere with tech support, dispite having the "advanced" subscription service.
I have also noticed it is far worse when working on drawings, It locked up for about 5 seconds when a moved a simple parts list 13 items long.
Any one else have any ideas?
Antivirus has been ruled out.
