Show only
Search instead for
HI Does anyone have(and want to share) a prconfigured Styles\template that translates Inventor std. layers to ACADM std.layers? eg. • IDW Dimension in Inventor is generated on the layer Dimension • Dimension in AutoCAD mechanical is generated on layer AM_5 I want to export an IDW in Inventor to DWG(AutoCAD Mechanical), I want the “Dimension” layer from Inventor to be translated to “AM_5” in the DWG file And the same for all the other standard layers Found this in the help menu: http://docs.autodesk.com/INVPRO/2010/ENU/Autodesk%20Inventor%202010%20Help/index.html?url=WS1a919382...
