Ok,
here is a test i've just done, i moved my diesel engine assembly (i
suspected was causing the issue) away from my project folder. So when i
tried to load the master iam it couldn't find it, so i skip it. Once the
master iam was loaded, i saved and exited just fine.
So how can i find what is causing this to happen in my engine assembly?
EL
"Sami Kozono (Autodesk)" wrote in message
news:5389200@discussion.autodesk.com...
EL,
Which release of Inventor (and SP level) you are uing?
I'm curious if unloading AutoLimits add-in makes things different or not.
Would you try it (if you are on R10 or 11)?
-Sami KOZONO
Autodesk Inventor Modeling QA
