I made a parametric assembly, where I linked the values of parts from an excel spread sheet, where I can create my assembly just typing the values. I'm creating the drawing of assembly but found some problems when update the assembly. The drawing goes to a big mess and I get some problems with dimensions. drawing1.png I show it's ok, but when change the values it will be a mess like shown in drawing2.png
I just want to solve the problem to create an assembly and drawings just typing values, thanks in advance
See the files attached. When I change the values from excel (e.g. double 20 40 50.. ) when update the assembly the drawing dimensions change the places, creating a mess
Hi
If you go to the Tools tab > Options panel > Document Settings button, and then click the Drawing tab in the dialog box, you will see an area called Dimension Updates. You might try adjusting that setting to see if it helps. If so you might want to edit your template and change the setting there so it is always set that going forward.
Dimension Updates:
Dimension Text Alignment controls text position for angular and linear dimensions when geometry is updated.
View Position maintains text position on the sheet.
Sheet Position and Maintain Centered retains centered dimension placement while all other dimensions maintain their positions on the sheet.
Percentage of Dimension Line attempts to maintain all dimension text positions relative to the dimension line.
I hope this helps.
Curtis
It doesn't work for me. I want to know if is possible to fix it by the center of asssembly and after I set the distance between dimensions or fix by one edge,
I'm afraid that there is no such option to constraint dimensions to view geometry or other dimensions.
The are "Dimension Updates Settings" that Curtis mentioned above but they obviously work for smaller model changes only.
You may want to post your idea (constraint dimensions to a geometry or other dimensions) to the Autodesk Idea Station.
Thanks for your post.
Martin Bernat
