Hi I created some drawing templates. Basically they are the same as the ANSI default ones except the tolerances are 3 decimal places vs the default 2. I saved them as templates. Everytime I open my template to use it I get a style conflict error message. See attached screen shot. After the message is cleared the template goes back to the original 2 decimal places. I renamed the templates a different name than the standard drawing.
Im using Inventor 2012 on Wiindows XP professional 32 bit machine.
How do I fix this problem? Thanks,
Bob
You can see this thread where a number of suggestions are given for the same problem:
http://forums.autodesk.com/t5/Autodesk-Inventor/Style-Conflict/td-p/3020008
