Hi
I am having another problem with Inventor 2012. Certain part files create "draft" views. I created this particular part in EDU version of Inv 2011. I have since purchased my own seat of 2012. When I made a drawing of said parts in 2012 all are "draft" views. I have no idea what that means or how to fix it. Print preview of drawing is missing many lines, but it seems to print ok. I get the following "update views" message, see attached, but if you click yes the views never update.
Thats another issue. why do I keep getting part or drawing created in education version messages even after I have opened and saved part in 2012?
Any suggestions other than recreate part in non Education version?
Bob
That is the solution to the edu banner portion of your question.
There is a hotfix available which could solve your issue. Please install the following hotfix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235749&linkID=9242019
If it does not help, could you please send me your dataset at
oto DOT kaleja AT autodesk DOT com
Thanks for your report!
Oto Kaleja (Autodesk)
