Hi all,
I've notice that gear models generated by design accelerator are actually intersecting with each other by running the "analyze interference". Can this be solved? I just don't get it. Aren't they not supposed to be intersecting? Are the models generated are meant for illustration and presentation purpose only? Or am I doing it wrong?
Thanks.
Solved by JDMather. Go to Solution.
Thanks.
Yes, like the cosmetic threads - the gears are for visual. Most gears would be purchased off-the-shelf, so there is no real need for complex toothforms. The spur gear generator uses the Wellman's Odontograph technique of simplified representation.
For the spur gears - you can have Inventor generate true Involute Curves and you can specify the desired clearance.
If you need true Involute curves with no interference between teeth - the process has been covered here many times in the past - a search might turn up the relevent discussions.
Post back if you cannot figure out how to get Inventor to create true Involute Curve from the Gear Generator Design Accelerator.
@Anonymous wrote:
@Anonymous wrote:Are the models generated are meant for illustration and presentation purpose only?
Thanks.
The closest thread that I can find is this, Does Design Accelerator generate real gear teeth yet? from years ago.
The link provided in the thread isn't working anymore.
I will try to look for more.
Would really appreaciate if you could shed some light on this.
In Inventor - right click everything for hidden functionality.
