Inventor Forum
Inventor crashes when new "norm.ipt"
10 REPLIES 10
Message 1 of 11
erhardtalex
1121 Views, 10 Replies
When I want to create a new norm,ipt, inventor crashes, after loading some things (shown in the left below).
Can somebody help me pease? Thanks! Smiley Wink
10 REPLIES 10
Message 2 of 11
blair
in reply to: erhardtalex
Is this a new installation or did this just start happening.
System spec's and IV version help as well.
Delta Tau Chi ΔΤΧ
Message 3 of 11
cbenner
Hello and welcome...
Um,... what?  Norm.ipt?  Do you mean a template?  Your post says shown in the left below... there is no image or file attached.  What version of Inventor?
Message 4 of 11
MariaManuela
Welcome.
Inventor 2014? If yes...The 2014 version came out a little unstable 🙂
Please install as soon as you can the Servce Pack 1 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Asidek Consultant Specialist
www.asidek.es
Message 5 of 11
erhardtalex
I have Autodesk Inventror 2014.
It happens since the installation.
As you can see in the Attachment, its a template I want to make.
I downloaded the latest graphic driver (nvidia geforce gtx 660m), but it also did not help, it still happens.
Message 6 of 11
erhardtalex
I also installed the service pack 1
Message 7 of 11
blair
When you installed were you logged with with Admin privedges?
UAC slider set to lowest setting, depending on your Anti-Virus, some versions require it to be disabled for the install.
Delta Tau Chi ΔΤΧ
Message 8 of 11
erhardtalex
1) Disable Firewall
2) Install Inventor 2014 as administrator
3) Run service pack 1
4) start Inventor -> still the same
Message 9 of 11
blair
Looks like you are trying to open a template file. Possibly there is something wrong with the "Norm.IPT"
Does it work with the "Standard.IPT"
Did you do a complete unistall of Inventor before re-installing?
Delta Tau Chi ΔΤΧ
Message 10 of 11
Hi erhardtalex,
In addition to the other suggestions, you might also try to run under the Software mode, in order to rule out graphics issues:
http://inventortrenches.blogspot.com/2011/01/graphics-issues-application-options.html
I hope this helps.
Curtis
Message 11 of 11
JDMather
in reply to: blair
I suspect Norm is simply a translation of Standard.
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
