Hi all.
Could someone please help me with the following?
I want to create a new part from within the assembly environment.
Now when I di this there is no centre point to constrain a skech to?
It works fine when creating a new part just not from the assembly environment?
Thank you in advance!
Solved by mrattray. Go to Solution.
Solved by JDMather. Go to Solution.
Project Geometry the Center Point from the browser when you start a new sketch (this should be your default).
Can you attach a small sample assembly that exhibits this behavior?
(Have you started a new sketch in the new part? )
Thanx for the quick reply!
I tried projecting it and it woked 100%
And my option box is now ticked!
Thanx alot JDMather & Mike (not Matt) Rattray
@Anonymous
First welcome to the community..
Secondly there has been a lot of odd activities lately on the forums with attachments and etc with no information being provided except for the attachment. If you truly have an issue/question/concern please describe the problem directly in the posting and not just provide an attachment. In addition this posting is 4 years old and you really should've create a new one at this point. At this time I'm not taking the risk of opening your attachment without additional information from you.
Mark Lancaster
& Autodesk Services MarketPlace Provider
