I am using Inventor 2012. In a bill of material can the column descriptions go from one lin to two lines.
See attached word document.
for example.
To: QTY
NO
First, what you are showing is a Parts List, the BOM referes to the assembly. There is a difference in how you can work with them.
It looks like, if you make the column skinnier, the contents will word wrap to multiple lines... but not the column header. Just another deficiency in Inventor tables I think.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This is the only way I know to have multiline headers.. (scroll down under Fig 3)
And it does work.. (just tried in 2014 anyways)
http://beinginventive.typepad.com/being-inventive/2011/08/
Brilliant!
Chris Benner
When I changes the parts list descriptions the column width was not long enough and the text did not wrap.
I had to increase the width to see the words.
