Hey Guys,
Ive started looking for someone to fill an Inventor 3d cad designer position at our facility and alot of the resumees ive been getting back has Revit as a 3D cad program that the applicants have used.
I have never used Revit and from my brief glances as to what the software does, it is, primarily, an Architectural tool and looks quite different from Inventor.
Anyone who has Inventor and Revit experience, what are the similarities between Inventor and Revit from a modelling point of view? If you know how to use Revit, will you be able to, proficiently, model in Inventor as well? Or is it like saying i use Autodesk AutoCAD so i can use Autodesk Inventor as well because they are both Autodesk software?
-daniel
Solved by pcrawley. Go to Solution.
The similarity between the two products ends at the manufacturers name on the box. There isn't a single common feature or function between the products (other than perhaps the View Cube, and even that behaves slightly differently).
As you say - it is just like someone saying "I can use Inventor because I know AutoCAD". Not even the basic principles are similar. Inventor connects lots of individual files to make assemblies and drawings - Revit has one giant file that contains model and all the drawings. They really are totally different products. You'll quickly find out if you sit a Revit user in front of Inventor and ask them to draw something!
