attached are 3 files that demostrate what is happening when I select a profile to loft and the rails of the Surface and how it changes the profile and how I can get a straight back edge not bowed in like it did to the front
Solved by JDMather. Go to Solution.
I am not familiar with editing jpg files in Inventor.
Why didn't you attach the ipt file?
becuase I hit submit before I attached it ..............sorry, it should be attached now
The entire part seems to me to be poorly done.
I would (almost) never ever use Fixed constraints.
The dimensions don't make logical sense to me?
The arc in Sketch7 used for a rail is not connected to the profile sketches 1 & 3 (this seems to be the biggest problem - taken care of with a simple Project Geometry - you should constrain all sketches).
You might add additional rails for more control.
yeah I agree ... file was not done by me , someone else , so I didnt know what he was trying to get accomplished or what shape he ws looking for nor what he was looking to produce ... thanks for your help, I dont deal much with surface if I dont have to , usally try to deal with solid if at all possible
