Show only
Search instead for
Sounds like a job for Dynamic Simulation. Do you have Inventor Professional? Can you zip and attach what you have so far?
----------------------------------------------------------------------------------------- Autodesk Inventor 2019 Certified Professional Autodesk AutoCAD 2013 Certified Professional Certified SolidWorks Professional
If you can drive the assembly with imported excel
based parameters, then go into Inventor Studio, that may work. I haven't
tried, but it seems like it should work. --
Hey there, it is defiantly possible with a macro. Look at [http://modthemachine.typepad.com/files/ipropertiesandparameters.pdf] or open the site [http://modthemachine.typepad.com/] and go to Inventor API: Exploring iProperties and Parameters. Read the bottom and download the sample programs. You should be able to modify those to do what you want.
