I've been attempting to animate the attached assembly, but I've been running into issues with getting the wheels to essentially rotate 20 degrees left and 20 degrees right (basically the physical limitations of the real RC car's stearing. I had it working last night (with a couple different constraint options), but Inventor 2013 crashed before I saved the file. I can get the wheels to spin just fine; it's the rotation of the wheels/axle attachment (shown in red in Inventor) that I can't get to function correctly. Any help that could be given with this would be great!
The assembly files are attached below. Sorry, it wouldn't let me attach the zip folder, since it was too large apparently.
Solved by rdyson. Go to Solution.
Thanks so much! I actually had it working yesterday with mate and angle constraints (not sure how I magaged that), but it crashed. Was the issue the insert constraints that you added? I figured I was making things more complicated than needed.
< Was the issue the insert constraints>
No, I just deleted your constraints and re-constrained so I understood the assembly.
After looking again I see that your angle 6 has limits set. Uncheck the limits and the animation works as expected.
