I have a frame that is built with the frame generator. When I run the simulation, Inventor will show the the shear, moment and stresses in each member in the frame. What I need to be able to get into a report, is this information for each member. (See below).
Inventor will give me a report, but it is just the min and max for the entire frame and not of each member.
Is it possible to get this information from inventor?
Hi Kirk,
Currently, there isn't a way to include the Beam Detail information in the report. We can include the Diagram information, but it doesn't contain results scale or beam length information.
I've logged in our database as 1395793 as a wishlist item to be considered for a future release.
We appreciate you bringing this to our attention.
Hugh,
I am running 2011, but it sounds like that you are saying that this is not possible in 2012 either. Is the report information the same between the two releases?
Hi Kirk,
We haven't made any significant changes in the report structure between R2011 and R2012.
Best regards, -Hugh
