Inventor General Discussion
sandhup
Message 11 of 33 (907 Views)
Re: Inventor Simplification Technology Preview available on Autodesk Labs
08-23-2012 07:47 AM in reply to: scott.sheppard
Some problems I'm experiencing with this;
I tried simplying an assembly with 2000 occurances, it returned an error.
Also the area, where you select include/exculde compoents disapeared and then re-apeared.
Employee
EvanGu
Message 12 of 33 (878 Views)
08-30-2012 12:15 AM in reply to: jeff.aguilera
Hi Jeff,
Could you please let me know which command fails and what the error message is?
Evan
scottmoyse
Message 13 of 33 (830 Views)
10-27-2012 07:15 PM in reply to: sandhup
This is a very nice tool, the various selection filters are phenomenal, well done. But there are some workflow issues:
  1. Why is it using View Reps instead of LOD's?
  2. Once you use the Combine Components tool, there doesn't appear to be a way to use the resulting part file as a substitute in the assembly without placing it in the assembly as a reference component and controlling it all via an LOD.
  3. If you have Voids to fill then you have to edit the derived assembly from within the part file, jump to the options tab then turn on 'Remove all internal voids'. Which is fine, however, it fails if you do this after having capped any holes.
  4. Often there are 'open' pockets or slots between components which need to be filled, but there's no option to do this with any of the simplification tools in Inventor to date, it would be nice if this tool addressed that in the future by 'welding' faces together within a certain tolerance of each other, but also with a manual override if needed.
I think that covers the issues I've discovered.
Cheers
Scott.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Board Manager
scott.sheppard
Message 14 of 33 (790 Views)
10-29-2012 06:46 AM in reply to: scottmoyse
Thank you for the detailed suggestion.
Scott
Scott Sheppard
Program Manager
Autodesk Labs
sandhup
Message 15 of 33 (705 Views)
12-20-2012 03:32 AM in reply to: scott.sheppard
Some times if I have parts with holes I want to block in an assembly as I go round to each part and open, I perform detect holes and press accept and it will crash. This happens on different parts each time I do this, not the same part.Blocking Holes In Assembly.jpg
dkt
New Member
dkt
Message 16 of 33 (615 Views)
02-28-2013 05:13 AM in reply to: scott.sheppard
Today I found out that this tool can be usefull to quickly simplify an assembly for Stress analysis.
Board Manager
scott.sheppard
Message 17 of 33 (571 Views)
03-19-2013 08:22 AM in reply to: dkt
I am glad you find this technology useful. That's what we need to hear during the preview stage to encourage us to continue to develop the technology.
Scott Sheppard
Program Manager
Autodesk Labs
New Member
tmaleski_dlb
Message 18 of 33 (504 Views)
04-15-2013 11:49 AM in reply to: scott.sheppard
I am NOT an Inventor user but a Revit user.  I recieved a large SAT file and Im trying to reduce it by using this tool.
I do NOT see the Simplify tab, is there a way to get it to display?
I do have the BIM Exchange tool which worked but would like to try this new tool out.
blair
Message 19 of 33 (479 Views)
04-15-2013 09:58 PM in reply to: sandhup
Then you will like the new tool in IV2014 for conversion to Revit
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Member
discglide
Message 20 of 33 (397 Views)
05-31-2013 08:06 AM in reply to: scott.sheppard
Simplify seems like it could be a great addition! but i'm encounter an error when trying to "combine compnents" i get an error dialog stating "the operation failed" and takes me back to the original assembly.
 What am i doing wrong? or is there a bug?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
