Inventor Forum
Inventor Sheet metal question for a trash can?
15 REPLIES 15
Message 1 of 16
Dotson13
959 Views, 15 Replies
See this pattern I have drawn up to go around this trash can? My question can you draw the the trash can flatten it cut this pattern out and refold it and will the pattern still be there in the round? I tried and it hasn't been successful is there any way I can do this? Thanks.
15 REPLIES 15
Message 2 of 16
ampster401
in reply to: Dotson13
Welcome to the forums,
This is the AutoCAD forum.
You will want to go over to the Inventor forum;
http://forums.autodesk.com/t5/Inventor-General-Discussion/bd-p/78
To answer your question, yes.  You can start with a flat sheet, do any modifications to it and then roll it up.
Message 3 of 16
Dotson13
in reply to: ampster401
Thank you. Can you walk me through it if its not to much to ask? I'm kind of new with the sheet metal process.
Message 4 of 16
JDMather
Can you attach your *.ipt file here?
Your sketch appears to be a pattern - so first thing I would do is delete the extra geometry.
You might also investigate the Windows Snipping tool for doing screen captures.
Simply go to the Windows Start Globe in lower left corner of screen and type Snipping in at the Search Programs prompt.
Message 5 of 16
Dotson13
in reply to: JDMather
I sure can i'm new to the boards how do I insert the ipt file?
Message 6 of 16
JDMather
Click Reply then click Browse in the Attachments line you should see below the text box.
Message 7 of 16
Dotson13
Message 8 of 16
Dotson13
My goal is to get that pattern to go around the trash can and I thought it would be possible to do it with sheet metal but i'm new with the sheet metal process.
Message 9 of 16
admaiora
You can use Emboss /Wrap to Face in 3d model tab
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 10 of 16
JDMather
While someone is preparing a solution - have you installed all Service Packs for r2103?  (the correct answer is No.  You might want to do this)
Message 11 of 16
Dotson13
in reply to: admaiora
But embossing it I won't be able to cut it out of the 3d object right? Is that my only option?
Message 12 of 16
admaiora
Edited- Corrected
Admaiora
Message 13 of 16
JDMather
Emboss can be set to Cut. (Engrave)
There are several other options as well.
Message 14 of 16
Dotson13
Sorry so when I emboss that pattern on to the 3d object will I be able to cut that pattern out of the object?
Message 15 of 16
JDMather
Message 16 of 16
admaiora
As JD said you can choose different way you can emboss until cut throght the part, you can unfold, cut and then fold, etc.
Admaiora
