I am a new Project Lead the Way teacher, using Autodesk Inventor for the first time. One of my students accidently hid the Ribbon and Browser and I cant seem to get it back.
The only thing that is visible is the "Quick Access" toolbar.
In the past, I have been able to find the "User Interface" function under the "View" tab, but without the Ribbon, I cant do that. Does anyone have a suggestion?
Mike Lazere
Hit this button.
It turns out that this solution didn't work. The student only has the quick task tool bar (gray) but the black bar beneath that is missing. Is there any other way to bring back the Ribbon?
I had tried to move the Quick Access toolbar before, but that option was grayed out. The only option I see when I RMB on the gray bar is "Restore". I won't be able to test this until the student logs in again on Monday. Do you think that will work? I don't see "Restore Ribbon"
Mike
Marshalltown HS
Here is how I fixed mine:
1.Hit the little button and WAIT.
2. Count to "5 mississippi".
3. It should appear. If not , go to 1.
4. there are only 4 options for this button, the "normal ribbon" is one of them.
Reinstalling inventor to fix this is nothing I would ever do-but that is just me.....
Carey,
Welcome to the forum.
See if this link helps you restore your ribbon.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Mike,
The behavior does not sound right to me. When you say the Ribbon Bar is missing, is that the entire Ribbon Bar and Panels are not there and only Quick Access Bar is available? Could you take a snapshot of the screen (print screen) and post it here?
Many thanks!
I am stuck with the same problem in Inventor 2014. Nothing Works. Not even the Link posted above. as thats for 2012.
Ribbon and Browser just dissapeared.
been struggeling for 6 hours now.
Maybe i should just get IT to do re-install.
IIronDog,
Clicking the black down arrow doesn't do anything for you?
Nope.
Gives a few options but not to bring the Ribbon back.
RMB on the side of the upper area ...and this will come up ..hit reset ..then what happens?
the upper Area where "Autodesk Inventoer Professional 2014" is?
Nothing happens Except this.
If i RMB on the black arrow.
I dont have an area like that...
I just have the Application Bar at the top.
