I'm sure I'm not the only one with this problem, but a few days ago, Inventor was working just fine, then out of nowhere, when I go to click on "New" it freezes, and gives me the "Not Responding" message. I have tried completely uninstalling the program, re-installing. Nothing has worked. I also have Service Pack 1, and the Update for Service Pack 1 installed, neither of which have fixed the issue. Any and all help would be greatly appreciated. I am also running Windows 8.1, but it was working fine even after the install of Windows 8.1, this has just suddenly happened.
Thanks!
Hi kaedenradde,
If you go to the Tools tab > Application Options button > Hardware tab, does changing the setting to Compatiblity or something else improve things?
I hope this helps.
Curtis
Blair,
I tried running the program, and creating a new part under the Guest account, and it worked just fine, so it must be something similar to what you described! Could you help me with the rest?
Thanks!
I am having similar issues, except when i select the drop down menu, nothing from their will launch, i.e. I can not select create new, open, or if i have a file open then i can not export. To clarify I can click the menu to drop down, but when I click open/new/export etc. its almost as if it is a blank button and has no action
Got same issue here with drop down Menu. Logged in as other user works fine.
Tried reseeting user environment as per your suggestions. Still have no reponse to any "I pro" menu items.
Any thing else I could try ??
Tnx MRB
I found the issue..
Jeez really...
I customised my fount size to 110% because my eyes aren't as good as they used to be......
This for some reason hides the tasks performed on the drop down menu..
Put the font back 100% & everything now works agaiin.
