I have an IV FEA study of an assembly. It has 6 load cases each with different constraints, meshes, and loads. Is it possible to send this collection up to the IV Optimization servers?
I am not trying to vary component sizes or anything, I just have several different load sets that need to be analyzed.
Steve Walton
Solved by dave.anderson. Go to Solution.
It sounds like you want something like a Cloud FEA server. Optimization is intended to change the size of the part based on given input criteria.
You can set up and run Multiple FEA Analysis configuration using a Parametric study OR individual Analysis simulations but those all take place on your local machine.
That is correct, I was hoping to use Adesk servers to speed up the analysis time for several complex studies.
Oh well, I will just run them overnight.
Thanks for your help.
Steve Walton
Dave is correct, Stress Analysis doesn't support cloud solves.
It is kind of a one-way street between Optimization and AIP Stress Analysis. You can export the Optimization simulation to Stress Analysis, but not vice-versa.
You may already be using this functionality for desktop solves, but I thought I'd mention it anyway. To solve a batch of simulations in SA, you can shift + select several simulations at once in the browser. When you press Simulate, it will solve them all in one shot. This makes it so you don't have to wait for a simulation solve to finish before (manually) launching the next one.
Best regards, -Hugh
