Inventor Forum
Inventor LT- path
3 REPLIES 3
292 Views, 3 Replies
Inventor LT- path
Using Inventor LT - path does not pull in the file from database when using Inventor LT. Inventor LT does launch but file does not open.   Please help!
3 REPLIES 3
ampster402
If I understand your issue correctly, what happens if you first launch Inventor LT then use the Open command from there to locate and open your part file (.ipt)?
If you're attempting to open a .iam file (assy), LT doesn't do assemblies.
in reply to: ampster402
when file is opened from Inventor LT, opens correctly.  But when the path is put in as launch application in database, it launches inventor LT but does not open the .ipt file.
ampster402
Sorry, I can't provide any assistance with launcing Inventor or LT like this.
good luck with this one.
