Inventor Forum
Inventor Keeps Crashing???
2 REPLIES 2
199 Views, 2 Replies
Everytime I open an assembly, Inventor immediatley crashes. I have
sucessfully opened same file at another computer. What do I do? Any
thoughts on what I should do???
Jeff
2 REPLIES 2
Look in CF for "Troubleshooting Inventor Stability Document", posted
7/2/03. That will give you a good start on finding your problem.
> Jeff
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4403 w/registry update
Dell UltraSharp 19" LCD
Try running Inventor at the command like with the /Install option. This
will rebuild the personal profile in the registry. In example; using
Start / Run from the windows task bar, type
"C:\Program Files\Autodesk\Inventor 7\Bin\Inventor.exe" /install
The quotes are significant
If you need to type in Inventor 6 instead, consider upgrading.
>Jeff
