Try running Inventor at the command like with the /Install option. This
will rebuild the personal profile in the registry. In example; using
Start / Run from the windows task bar, type
"C:\Program Files\Autodesk\Inventor 7\Bin\Inventor.exe" /install
The quotes are significant
If you need to type in Inventor 6 instead, consider upgrading.
Jeff Dickerson wrote:
>Everytime I open an assembly, Inventor immediatley crashes. I have
>sucessfully opened same file at another computer. What do I do? Any
>thoughts on what I should do???
>Jeff
