Inventor Forum
Inventor - Drawing - Revision table
8 REPLIES 8
Message 1 of 9
JamesNordgren
1014 Views, 8 Replies
Someone out there has got to know this one:
Problem Statement:  When I insert a rev table on my drawing it comes in with the Rev value at 1, even though the Revision Number property for the drawing is set to zero. Even worse, the cell has the Static Value checked, so that it will never update unless the user edits the table and unchecks it!
How can I stop this from happening?
8 REPLIES 8
Message 2 of 9
mdavis22569
in reply to: JamesNordgren
What do you want to be ... We use A/B/C during submittal stages ... Then "0" for Released to Fab ... then 1,2,3 if any changes are required. We have to RMB and override the 1 to be a "0" then we just from from the adding
Mike Davis
Message 3 of 9
JamesNordgren
in reply to: mdavis22569
Thanks Michael Davis,
I want the initial value to be zero.  Actually, I wouldnt care what the initial value is if the table would just come in without the rev field being set to a STATIC value!!  User RMB and unchecking this is not an option, because I am now automating our drawings through ETO/iLogic.
Again,  anyone please tell me how to prevent a Rev table from coming in with the rev field checked to STATIC VALUE??  If this is not a bug, then I will be darned if I can find any way to control this behavior.  API has nothing it seems...
James
Message 5 of 9
mcgyvr
in reply to: cbenner
When you press the Revision button to create the table are you not prompted with this dialog box? (note the update property on revision number edit)
Also what version of Inventor?
Message 6 of 9
JamesNordgren
cbenner,
Thanks for your reply.  It has nothing to with styles settings however.  I believe I found the proper method in API now which allows direct control of the StartingValue parameter
Message 7 of 9
JamesNordgren
in reply to: mcgyvr
Yes, mcgyvr, but I am doing this in Intent code (ETO) with an API call, so no user intervention...
Message 8 of 9
mcgyvr
So maybe there is a setting or flag or whatever that you need to set through ETO to enable that so the table is NOT set with that enable update option.. yep bet thats it.
Message 9 of 9
Ktomberlin
in reply to: mcgyvr
JNORDGREN, Did you ever find a solution within the API to enabling the "UPDATE PROPERTY TO Revision Number" option?
