Inventor Forum
Inventor Base View to Autocad
3 REPLIES 3
ahogue
944 Views, 3 Replies
I have plotted a base view of a part onto a sheet of my idw file.
I would like to take the lines generated from the part's wireframe and edit them in autocad.
I know that you can export parts to autocad from inventor, However, this exports the entire 3d part.
If i export the entire 3d part, There are many other lines present that would be otherwise invisable viewing it orthographically.
How can i simply take a base view from an idw and edit it in autocad?
3 REPLIES 3
blair
in reply to: ahogue
Just export the IDW drawing to Autocad and select the correct version in the options.
You should also be able to create your base view as a DWG and this will allow for editing in Autodesk Autocad.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
in reply to: ahogue
Depending on what you are doing - you might not even need an Inventor drawing.
You can right click on a planar face of a 3D object and select Export to *.dxf or *.dwg  to get the 2D.
PaulMunford
in reply to: ahogue
Or - use DWG instead of IDW, then you can open the inventor drawing in AutoCAD and insert the view as a block.
Heres how it's done: http://cadclues.blogspot.co.uk/2011/05/how-to-extract-2d-autocad-geometry-from.html?m=1
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
