I am working in an assembly file. Our company just upgraded to 2014.
I cannot copy / paste components by selecting on screen anymore, or by using the command on the ribbon.
Is there a solution for this matter?
Thank you for reproting your findings.
This issue has been known as DID 1498780 in our product database.
Development has identified the cause of the issue and made some code changes.
(It's not reproducible with a recent internal test build any more)
Thank you,
-Sami Harada
Inventor Framework QA
Good Morning Sami,
How do we go about resolving the issue if it is occuring at our site? Should we submit a support request through our subscription account? Please advise.
Thanks.
At this time, full details are not available in terms of release date of update/service-pack.
The issue happens when the component path (folder\...\file) + occurrence information is too long.
Possible workaround would be:
* Move the whole project to a shallower path, or
* Edit the X, Y, Z Offset of the two occurrences via iProperties -> Occurrence and change them to all 0
Hoe this helps
-Sami Harada
Has this issue been resolved? Is there an update fix yet?
I can't copy any components in inventor assemblies ... really annoying
Cheers,
Ben
