I have created drive constraints for my assembly file. They will animate correctly whenever I press play in the drive constraint field inside of inventor assembly. however, when i go to the inventor studio the same drive constraints will not animate. They do not move at all. Is there a specific reason this is happening? Is there any way to check if I'm doing something wrong?
Any advice on this delimma is appreciated.
Nathan
Hi
You can not add the file here?
Attach your assembly here.
Also search Google on Bill Bogan Inventor Studio
and
search http://au.autodesk.com on Mark Flaylor classes.
I really want to but the project im working on is patent pending and not mine. Do you know if there is a default trouble shooting process I could follow?
Nathan
Hi Nathan,
I have a video about animating restrictions in studio. Give me your email and I send you.
Is to large to attach here.
