I have a file created in Inventor 2014. I am trying to export the file as a STEP file, and have tried every other format and combination there of. Inventor crashes during every export. Other files work perfectly well.
I just can't get this file to export out. Any help would be greatly appreciated.
Solved by CCarreiras. Go to Solution.
Hi!
I think you had a issue in your part: The multisolid had 3 solids, but in reallity you had only two, so i redo the last extrusion and selected one of the 2 firsts solids to cut, and that way, the part maintained 2 solids in the final.
Export, and, worked!!!
Part in attach.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Thanks for the quick turnaround!
And thank you for the solution, didn't even think to check that.
You could have a try when R2014 SP1 is available.
