Inventor Forum
Inventor 2014 cannot selectively import AutoCAD DWG files
4 REPLIES 4
DaveC_
373 Views, 4 Replies
I have been having problems importing DWG files into Inventor. The selective import does not work at all. However, I can import simple DWG files. Importing complex DWG ones seem to cause Inventor simply to crash.
I have read the forums here and none of the solutions suggest were effective for me. i.e.
  • I have uninstalled and reinstalled TrueView.
  • I have tried to register with RegSvr32 the acctrl.dll file, etc...
  • I have tried to wipe all my user settings
  • I have tried to run inventor.exe /install
 Please help!
4 REPLIES 4
Curtis_Waguespack
in reply to: DaveC_
Hi DaveC_ ,
You might try the solution at this link:
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
I hope this helps.
Curtis
DaveC_
in reply to: Curtis_Waguespack
Thanks Curtis. I tried this and it did not work for me.
JDMather
in reply to: DaveC_
If you can import simple sketches, but not complex ones - it sounds like a constraint issue.
What happens if you turn off the creation of constraints?
What happens if you convert to block in AutoCAD and to an Inventor Sketch Block.
The CADWhisperer YouTube Channel
Curtis_Waguespack
in reply to: DaveC_
Hi DaveC_ ,
To support what JDMather suggested, have a look at the Paste Options described at this link:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-F7601F0D-21B8-4746-B37D-A80429CA73E2
These options are used when you Copy from AutoCAD and Paste in Inventor, rather than using Inventor's DWG import wizard.
I hope this helps.
Curtis
