Inventor Forum
Inventor 2014 - Title block fault
2 REPLIES 2
HenrikGraversen
984 Views, 2 Replies
I got a huge problem with a title block.
I made it in Inventor 2013. And migrated it in to Inventor 2014.
But now the texts are totaly messed up. It makes no sence!
I used some iProps from the part and some from the idw.
from part:
custom iprop model: <Vaegt>. But in the titleblock it only write "aegt". The data is fine.
iprop model company: In the titleblock it write "compan" og "cmp" depends on what idw i open. The data is also shortened / wrong.
and so on. Most data is missing or shortened.
Is there a solutiuon for this?
Kind regards
Henrik Graversen
2 REPLIES 2
I had a similar problem with some of my custom section headings being move/changed by the converting prosed. These were changed from top left justified to middle middle for some unknown reason I've never had that problem before.
The other things was that I have two custom templates one for inch with another for mm both had different coloured section headings blue for inc and red form metric these also got screwed up to all black the other problem was that a custom logo had also been moved and had to be repositioned
All I could do to correct my problems was
1) Create a new IDW with the existing, now faulty template.
2) Import any customise dim etc. into each affected template
3) Edit the Title block
4) Save as template
Yes it's a bit of a clart around but it seems to be the only answers to this problem. Don't know what if anything has changed in the conversion process but something has.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Today the problem was gone.
All is good now.
A reboot fixed it 🙂
