Inventor Forum
Inventor 2014 Ribbon Customizing
12 REPLIES 12
Message 1 of 13
1973 Views, 12 Replies
Confirmed!  My copy of Inventor 2014 will not remember the customizations I perform to the ribbon.  I simply added the PDF command to the Drawing/Vault/ ribbon, and when I save and close properly and reopen, the customization is gone.  It did remember all my custom keyboard commands, just not the ribbon command.
Does anybody have some information I can use to fix this?
jvj
12 REPLIES 12
Message 2 of 13
ChrisMitchell01
Jamie,
This is indeed a problem related to customizing the vault related Ui; it's planned to be fixed in the first vault update, (sometime in June). I'm not aware of a workaround for this.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 3 of 13
in reply to: ChrisMitchell01
It's not just the Vault add-in. None of the tools I put in the QAT stay there. everytime I open another file, the QAT looses all the tools I had previously placed.
Message 4 of 13
A pain in my bum...
Please fix this issue.. I installed 2014 Update released on 9th of May.
This issue is not fixed....
Message 5 of 13
guido_66
This problem has been there with all Inventor versions since the ribbon was introduced.
Message 6 of 13
Not true. All during 2013, I was able to keep customizations in both the Vault add in ribbon, and the normal Drawing default ribbon.  I wanted to be able to export to PDF from both ribbon items.
A major flaw I'm finding in 2014, which may be related, is the inability to consistently write to the registry.  This was evident from the settings found in the Application Options, being ingored after closing and reopening Inventor (without crashing!).  I was able to manually place the values (or remove) from the registry and get the effects I wanted but not always able to get them to 'stick' when I just used Application Options, and hit apply.
The registry location is posted below incase you wanted to know.  Don't go poking around unless you are an expert.  If you do, it would be a good idea to export the entire registry key before you mess things up, so you can delete your error, and re-import the original.
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences
Message 7 of 13
This has nothing to do with Vault. I'm having the same issue with my Swift Prints button on the QAT. It disappears on a weekly basis (sometimes daily).
I'm not a Vault user.
There has got to be a fix for this.
Message 8 of 13
This issue was fixed with SP1.
Charles Whitmire
Mechanical Application Engineer
1-866-912-4770
1003 Laurens Road
Greenville, SC 29607
CharlesWhitmire@TPM.com
[TPM, Inc]
Message 9 of 13
I didn't realize SP1 was already out there...just installed it now.
Now I can't get Swift Prints to go to the QAT at all. The RMB option to "add to quick access toolbar" is greyed out. So much for a fix, now it is even more broken.
Message 10 of 13
Try doing a repair from Control panel – Uninstall a program
Charles Whitmire
1-866-912-4770
1003 Laurens Road
[TPM, Inc]
Message 11 of 13
guido_66
Probably a reboot will fix it. I often need to switch back and forth between Inventor 2012 and 2014. When I do that, add to QAT is also greyed out. After a reboot it is normal again.
Message 12 of 13
SP1 did not fix the ribbon customization settings or the placement settings. I still have to relocate my undocked ribbons off the main screen to me side monitor for many projects and reconfigure the panels too. This has been the case for each and every version of inventor since the ribbon was introduced. I've complained in the past many times to no avail.
Message 13 of 13
I have the same problem. This has been the case for me ever since they introduced the ribbon. It has never been addressed.
i7
Win 7
24 gigs
Inventor 2014 x64 (latest update)
