Inventor Forum
Inventor 2014 - How to Reverse Mouse Wheel (Zoom)
1 REPLY 1
rkirk77
5625 Views, 1 Reply
I just re-installed Inventor 2014 on my computer and wanted to share this with the community.
Goto your Tools menu.
Select Application Options.
Click on the Display tab.
Under 3d Navigation section (very bottom), click the checkbox for Reverse Direction.
Windows 8.1 Pro 64-bit
Intel i7 870 @ 2.93 GHz
Nvidia GeForce 580 GTX 1536MB GDDR5
8 GB Ram
250GB HDD
1 REPLY 1
Curtis_Waguespack
in reply to: rkirk77
Hi rkirk77,
Thanks for sharing this tip with the community. I'm sure someone will search and find your post in the future and be quite pleased that you took the time to post.
As an added tip, if you'd prefer to set AutoCAD to match Inventor's default, you can use setting described at this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8221121&linkID=9240817
I hope this helps.
Curtis
