Inventor Forum
Inventor 2014 Error 0xC0000142 on Windows 8
130 REPLIES 130
Message 1 of 131
117606 Views, 130 Replies
I have uninstalled and reinstalled Inventor 2014 5 or 6 times and I am still recieving the error code 0xC0000142 upon start up.  I also have AutoCAD installed, which starts up fine.
Error Log:
<System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-08-06T04:17:38.000000000Z" />
  <EventRecordID>57992</EventRecordID>
  <Channel>Application</Channel>
  <Computer>Andrew-PC</Computer>
  <Security />
  </System>
<EventData>
  <Data>Inventor.exe</Data>
  <Data>18.0.17000.0</Data>
  <Data>512fe9d7</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.3.9431.0</Data>
  <Data>51bd0a54</Data>
  <Data>e06d7363</Data>
  <Data>0000000000006aac</Data>
  <Data>217c</Data>
  <Data>01ce925be255dd0e</Data>
  <Data>D:\Files\Programs\Autodesk\Inventor 2014\Bin\Inventor.exe</Data>
  <Data>C:\WINDOWS\system32\KERNELBASE.dll</Data>
  <Data>20365b99-fe4f-11e2-befd-3085a9991555</Data>
  <Data />
  <Data />
  </EventData>
130 REPLIES 130
Message 101 of 131
in reply to: aj17atj
@ChrisMitchel
could you send me the fixed files for Inventor 2012 Professional please? I need it for x64 version of windows 8.1.
many thx in advance
Message 102 of 131
ChrisMitchell01
All Inventor fixes have been released. Please see the relevent support page for your version from:
http://knowledge.autodesk.com/support/inventor-products/downloads#rows=10&sort=score&ADSKProductLine...
For 2012 you should install Update4 for SP2 - http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-4-fo...
Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 103 of 131
I have installed the Inventor Pro 2011 and I have the Windows 8.1 too. Everytime I open Iventor I get the same error.
What should I do?
Thank you, Daniela Alves.
Message 104 of 131
blair
in reply to: Daniela_Alves
Thank you for using the Search function on this user forum. Have you downloaded and installed any of the required SP's and Hotfixes for your product. http://knowledge.autodesk.com/support/inventor-products/downloads#?ADSKContentGroup-local=Downloads&...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 105 of 131
in reply to: ChrisMitchell01
Hi Chris,
is there any chance to get this fixed rse.dll file, too?
I installed the SP2 and Update4 but Inventor 2012 still isn't running on Windows 8.1
Simon
Message 106 of 131
12063061
Sir,
I still get 0xc0000142 errors... it's April now
Please help
Message 107 of 131
ChrisMitchell01
in reply to: 12063061
All fixes for running Inventor products (Inventor, Inventor LT, InventorView) have been released & can be downloaded from:
http://knowledge.autodesk.com/support/inventor-products/downloads#?rows=10&sort=score
You'll likely need to install the latest SP as well an update. After installing the update there is a manual step to perform as documented from each of the Update download pages - see the command prompt steps from http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Chris
Chris Mitchell
Message 108 of 131
Just got Inventor Professional 2012 running on Windows 8.1!
Here is exactly what I did for all the people encountering the same problem:
Cheers,
Simon
Message 109 of 131
mmeetsma
Hey Chris, how can I apply this fix to Inventor OEM 2013? So far Autodesk has refused to provide *any* service packs or update packages for it. Thanks.
Matt
Message 110 of 131
ChrisMitchell01
in reply to: mmeetsma
Matt,
Unfortunately you can't apply this to OEM. If you send me an email to chris.mitchell@autodesk.com I'll send you the affected file, but since that has build dependencies on other updates that were not released for OEM, I doubt it will work, but it's worth a try.
I've asked what's involved in getting a proper OEM version.
Chris
Chris Mitchell
Message 111 of 131
Maxe575
Chris,
I need to use Inventor 2014 to finish a project at school. I went to the Autodesk free downloads for education and spent a day downloading Inventor 2014 Pro. I recieved the application error 0xc0000142, and then found this blog. I read the entire eleven pages, and then downloaded sp2 for Inventor 2014. I found the admin command prompt and followed the instructions in the trouble shooting guide. When I get to the last step "inventor /install >press enter", I hit enter and the application error 0xc0000142 comes up. Inventor will not open. What am I doing wrong?
I have a Dell Inspiron 3521
Intel Pentium cpu 2127U @1.90 GHz
4.00 GB ram
64-bit OS, x64 based processor
full windows touch support
windows 8.1
My windows is fully up to date.
Thank you,
Max
Message 112 of 131
blair
in reply to: Maxe575
You were logged in with Admin Privileges and had the UAC slider set to it's lowest position when you installed Inventor and the SP?
Delta Tau Chi ΔΤΧ
Message 113 of 131
in reply to: mcgyvr
I have no idea what that means, but by the looks, your CPU OC seems to be a little week for the CPU you have, id consider crancking that baby up if I were you. Also A 770 classy wouldnt hurt either seeing as it is an nvidia card may aswell get a 4GB one so you can do more hardcore rendering and folding.
Message 114 of 131
Hi, I'm a first time Inventor Student. I am also having this 0xc0000142 problem, I've tried the uninstall, reinstall, and even repair. All of these have not worked.
Message 115 of 131
Hey, ive been trying to use this software aswell, unfortunately this
software doesn't work on windows 8.1 but "Apparently" they have a patch for
it that you have to opt in to get...
Message 116 of 131
ChrisMitchell01
Inventor works on win8.1 as long as you install the latest servick packs &/or updates. Depending on which Inventor version you are using you can get the appropriate fixes from http://knowledge.autodesk.com/support/inventor-products/downloads#?sort=score
There's no need to opt in for anything.
Inventor 2012-2014 requires an SP or update. 2015 should work without any.
-Chris
Chris Mitchell
Message 117 of 131
kolmay12
in reply to: chucksavatsky
I still have the same problem with this error 1 year later...
Message 118 of 131
Eqvaliser
in reply to: kolmay12
Same here, actually all of us just gave up on Inventor and found alternatives via the website
alternatives to ...
And we actually got a company to use the other software, because they wanted a new system designed
with Windows 8.1 and windows 10 Tablet design in funktion where Inventor wont even run anymore..
Just here to unsubscribe from this thread, after watching this for a year without any reasonable solutions!
Message 119 of 131
ChrisMitchell01
in reply to: Eqvaliser
You need to install the latest Service pack & updates - for 2014 see http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-in...
Chris
Chris Mitchell
Message 120 of 131
                 I am a Freshmen in high school, and I am taking a PLTW course where we use Inventor 2014. because I am a over achiever, straight A student, and I like Inventor. So I Downloaded the 3-year free Inventor Professional. As you could have guessed I also have Windows 8.1.
            Is there a way for me to commute my designs on the school's Windows 8 to my computer if I regester to use the Beta 8.1 version.
