I was working on an assembly and when I went to delete a part I got the error message as stated in the attached file
Have you installed Service Pack 1?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Have you rebooted the computer and the problem persists?
BTW - you can copy an image into MS Paint rather than a doc file, or simply use the Windows Snipping tool.
Tip #8675309- If using Windows 7 (and probably 😎 the best tool is the "snipping tool" for taking screenshots.. Its just much easier..
Its located in the accessories folder.. Pin it to the taskbar as you might find yourself using it all the time..
