We are trying to convert an old 2008 Inventor drawing template for use in 2013 Inventor. The drawing template has been converted to appearances and we are having problems with font sizes varying from the original settings.
The biggest problem is that the dimensions are appearing with a Default (JIS) standard that is 3.5 or 4.5mm tall and does not exist in the drawing template.
This Default (JIS) dimension standard appears when we create a new drawing with this template. How do we force Inventor to use the Nasco –Standard 2.0mm tall dimension style?
We have been able to overcome this problem by changing the style on each computer by hand, but this is tedious and will take some effort to get this changed on everyone’s computer.
Any help would be greatly appreciated.
So you don't have your styles on the network? This way everyone has the same?
Open the template, go to manage tab, edit styles and make sure the default standard in what you want.
Highlight that standard, then go to object defaults and see which dimension style is set there.
