Can some one give a good example of when to use "Find Thin Bodies" in the Prepare tab of Stress analysis. pros & cons od using vs not using it.
Solved by blair. Go to Solution.
I am sorry, but I did not follow what do you mean by HSS column? a Tubular column or a cylinder?
I am trying to run FEA on a an assembly. While meshing I encounter this warning.
I clicked the "Find Thin Bodies"; it prompting to create a "Mid-Body" and when I clicked OK, the whole model is replaced by a surface body.
Is this normal? Am I going in the right direction?
